CCOT sells the rain gutter channel and weatherstripping. Drilling out the pop rivets is the easy part. To get the metal pieces of the gutter assembly to line up and mark where to drill the pop rivet holes, you will need a fixture. Dad and I screwed some plyboard to some 2x4s, in a pattern around the perimeter of the fiberglass top. We then layed out the gutter, set the fiberglass top down on top of them, arranged them so they all fit together, then traced them out with a Sharpie (including the pop rivet holes). Next, we removed the fiberglass top, made sure the metal gutters lined up, screwed them down with wood screws and washers. After welding the gutter together, we drilled the rivet holes, painted the gutter with a primer, removed it from the jig, then began to pop rivet the gutter to the fiberglass top. Once pop riveted, silicone seal the inside and outside where the top meets the gutter, wait for it to cure, then paint. After that, simply bolt it on using the proper weatherstripping and hardware, and voila! New gutters!
Brian
