Pictured is my '92 LandCruiser hitch receiver setup, bolted into the stock pintle-holes. The bolts are Fastenal M12-1.25 x 50mm DIN 961 Class 10.9 screws with a tensile rating of 150,800 PSI. Top ones are threaded into the frame, bottom ones are threaded into class 10.9 nuts. The receiver adapter is by Rigid Hitch. In between the receiver and the frame is a mil surplus chain plate.
Mounted now is a bike rack that probably supports less than 100lbs total including rack and two bikes. It has never budged a millimeter and has always been rock-solid.
If I wanted to put a cargo basket on this, how much weight could it support? Hugely important is how far back the rack would sit. The nature of this setup means it will site quite far back (unfortunately). This would include beach driving so potentially bumpy. The goal is to put a 65Qt cooler and some other misc. gear on it. 65Qts of water weighs 135lbs, plus the 50lb (heavy duty Pelican) cooler plus about 50lbs for the tray for a max theoretical weight of 235lbs.
