F=-kx
for a torsion spring
t=-k(theta)
As we increase theta t will increase
Force would be the first derivative of theta right?
something like 1/2k(theta)squared
As we increase theta the rotational opposing force increases which would change the ride, no?
It's been something like 25 years since I took any ME courses so I could be wrong.
what everyone is missing is that there is zero change in force! The only thing that has changed is the neutral point. Vehicle still weighs the same, same radians of twist on the spring, same spring force opposing the LCA rotation. Everything is exactly the same as a standard height vehicle except the neutral point. Only exception is the effects of suspension angle and how that affects ride quality (y'all are on your own with that one!)
If all we need to adjust is the torsion bars, then it will be a really quick job as long as the bolt isnt too seized up. Has your truck always been in CA? If so, I dont think rust will be a big deal. Just hit the adjustment bolt with some PB Blaster for a few days before coming down. That will break loose any corrosion before hand. With no corrosion and as long as the tbars don't need to be re-indexed, it shouldn't take more than a 1/2 hour....and that is being generous.
You could drive back to Oceanside, however, there is a Firestone in PB like 2-3 miles from my house you could hit up before you head back north. Just dont do a ton of driving before getting the alignment done.
[strike]When you lift your truck without re-indexing you pre-load the springs, no? [/strike]No re-re-hashing...My whiteboard diagram clearly explains what you people are sensing as the "difference". Management Degree > Engineering Degree FTW!!!
But still... BOW TO OREGON!
Man you guys over complicate everything.... You can do all the math you want... when you change that angle it changes the ride quality. Leverage.
Truck was an East Coast Rig all it's life up until July 2011Mechanics said there isn't rust, shocking!
I could do some PB Blaster for you, lord willing I get the right bolt.
I'll try and find a pic of where these bolts are do that for you...
Think we can raise it more than an inch???
That won't do anything to it right?
I was hoping for 1.5".....
what happens if the bars need re-indexing? are we screwed?
jgray said:I be agreein with RR on this one... Cranking TBars changes other things related to front suspension geometry (CV angles, toe in, steering, etc)... Tiny adjustments may not be very noticeable but once you go up an inch or two it will ride different... An alignment will offset some of these changes but it still won't feel stock again... I've had all kinds of different setups at this point on my 100 and they all feel a little different...
Different feel and ride...but better or worse?
pfran42 said:What do you mean? Your better and my better could be worlds apart.
I'm my opinion, if you just crank the OEM TBs, it is just as "springy". It just takes a little more of a jolt to get them into their spring mode (vs. their static mode of just holding the vehicle a certain distance from the ground).
I too would have to pull out my books to validate the equation.
However, what everyone is missing is that there is zero change in force! The only thing that has changed is the neutral point. Vehicle still weighs the same, same radians of twist on the spring, same spring force opposing the LCA rotation. Everything is exactly the same as a standard height vehicle except the neutral point. Only exception is the effects of suspension angle and how that affects ride quality (y'all are on your own with that one!)
RobB said:I agree with this. "Zero Force Change" in the TB.
So for different reasons the ride will change mainly due to the negative effects by taking the torsion bars out of the preload range they were designed to operate in.
