Just picked up a replacement for my shorted out reverse switch on my 73 40 w/ 3 speed tranny. IS the switch a 12v or is it a negative like a horn wire? I plan on running a fresh wire off of the battery with a relay so I can run more than one reverse light.
If it is a 12V, can a run a fuse wire to the switch and that back to a relay. From the relay to the light.
Or can I only run a 12v fused wire to the switch and from the switch to my reverse light?
