The way the Haynes manual reads, it should just slide out but it appears the bolt that locks it in place broke and has cause it to move back an forth for a while. I noticed when I opened up the rear-end there was 1/4 inch of the shaft sticking out. I'm not sure if it's deformed or what but it won't come out easily. It turns so the locking pin does't seem to keep it from spinning in place.
I don't want to screw something up so I'm searching for advice before I get mad and start beating the ??|!&*^%$ out of it.
I added a picture which shows the lock pin - I've beat it pretty good to get it this far and it gets stuck pretty solid. I can push it back and the shaft turns freely.
1. Should it just slide out?
2. Does it matter which direction to remove the shaft? It seems to go one direction further than the other.
3. I assume there's no other way to get axles out without pinion shaft removed?
4. Final question - Why does everything I touch on this thing seem to take more time to fix and more money than I planned on? (I think I already know the answer.... I thought this was going to be an easy re-do.)
1975 fj40
1975 fj40
