I added larger tires and regeared so now obviously both are off. Wondering how to go about recalibrating it?
Tall jokeFirst things first, a miscalibrated speedo is very much an indicator of a head gasket failing. It probably hasnt failed yet but I would give @beno a call and get a 'valve grind kit' on order. You can read about other things to fix while youre in there. Good luck. IdahoDoug used to have a dvd that can help.
Yeah, the newer vehicles can repair the headgaskets with a software patch. Machine learning, data science. That sort of thing. But that's not supported on a vehicle manufactured before 2002 due to the IEEE 453.b standard that permitted electronic introspection. They had the technology but it wasn't DOT approved, pretty much.Guessing that is not it. The engine was completely rebuilt top and bottom about 10k ago. The speedo was off before that and off still. Again I am sure it is the tires and regearing. I know on the new Jeeps I just take it to the dealership and have them down load a software patch.
Ok so @nukegoat was just busting your ovaries about the speedo, I am sure you have one dem smart Phones there is an App that when you are driving it can tell you your speed, and then look at your speedo and see what it tells you, so like the app tells you you are going 55, but your speedo said 50, then you know about what the difference is, or you could go all @NLXTACY and go and find the exact diameter of your tires every day and then have a Ipad with a Ram mount to tell you by exactly the diameter of tire any given time
This may be a dumb questions but if my Speedo is showing 10 mph faster than I am going am I correct in thinking that my odometer is putting on more miles than I am actually going?
Look up Yellowbox. It is a Speedo correction that plugs into your OBD2 port (or OBD1) and will correct the speedo as I understand it.
These are done by wire from the sensor on the transfer case to the speedo. No direct cables here.......
Official home page of the Yellow Box Speedo Recalibrator
OK you gotta hook me up with your supplier.Yeah, the newer vehicles can repair the headgaskets with a software patch. Machine learning, data science. That sort of thing. But that's not supported on a vehicle manufactured before 2002 due to the IEEE 453.b standard that permitted electronic introspection. They had the technology but it wasn't DOT approved, pretty much.
