- Joined
- Nov 6, 2011
- Threads
- 105
- Messages
- 400
Has anyone used a speedo calibration unit? if so which brand would be the best to go with ..thanks
Personally I wouldn't mess with the gear (I don't even think it is available anymore). It doesn't give accurate correction and it isn't adjustable. The electrical correction is adjustable and can be tuned to be spot on with any tire size.
Nope. Never heard of an adjustable gear driven unit. $90 is cheaper than $200 if it works.Pretty sure your speedo is either gear driven or electronic.
I have a 91 fj80 so it's all "gears/cable"
Call these guys up they are great !
I posted this on a old thread I've got going,
I found a company that will make a gear case to correct the speedo assembly for around $90.00 the best part is its servicable, if you change tire size you can open it up and change the gears to yield the correct ratio. the companies name is speedometer service 800-634-2145
you must have never used a gear driven speedo calibration unit or used the wrong company, mine is adjustable/servicable and accurate they will custom make the correct gear set to match your setup. you tell them how fast your speedometer says your going when your gps showes 60 mph the calculation is baset of that "baseline"..
There still is some advantage to the electronic units in that you may have more than one setting so that you can change tires or wheels quickly and then simply throw the switch for the other combo. Also, you only pay $200 one time.
How much does it cost to reset the mechanical calibrator with new gears? Also, I assume that you have to get under the truck and change the configuration of the mechanical calibrator?
cruiser concepts said:It's great product made in Portland, OR USA!
Pretty simple to adjust, open the unit up and change the gear sets to get the proper calibration. To the OP, I personally run this product and it works well and you can't beat the price. Installs in less than 5 minutes and Replacement parts for it are available and it will be made to your calibration needs. Did I nmention it's made in the USA....
E-Nuffsaid.
Are they in Portland? Thanks, MIke
Please post product/company info. I'm interested.
They are $200 and the Truspeed calibrator I use allows you to set 2 calibrations without sending the unit away. Then you can switch back and forth between the two by the flick of a switch. If you want to change one or both calibrations it is quite simple.by all means spend $300 on an electric unit, im not that guy.
slee and others do not offerr differant calibrations they offer a "one size fits all application" and, well...... it doesn't fit all. pretty sure "slees" was made to correct 33" tires or something I don't remember. and it was allmost twice as much.
truck. Supposed to correct for 33's, but found it's still quite a bit off.
