OK, but shouldn't the source ground be the alternator circuit then? The battery is supposed to supply starter circuit power, then receive resupply current while the engine is running. Unless I missed something in design class, the battery isn't supposed to supply current to the accessory components (that is, everything except primary ignition circuit current draw).Frame is ground..... right....... but not a"good" ground! Most "hi draw" components (large investors, winch, etc) recommend running ground (same size as power) back to source ground....I.e. Battery. Otherwise..... if you go off the "frame is ground" theory, your working the components harder than need be, which equals..... shorter life. (Working harder = running hotter)
Please bear with me, I'm a mechanical engineer with only on the job electrical knowledge, but when I did work in vehicle design, we always designed the power circuits with a battery cutout, so that nothing could draw current from it after the ignition circuit became self-sustaining. In addition, the battery itself is connected to the vehicle ground. How does that change the current flow if components are grounded through the body/frame? Unless there's a break somewhere in the body/frame between the battery ground connection and the local component ground, there's a continuous circuit, right?
