Sadly decided that as much as I love my 40th I need a V8 to tow and cover ground a bit faster as a DD....so likely jumping into a LX/GX 470.... not in a rush to sell but rather looking for someone who will enjoy the rig as intended.
I've always coveted a 40th since I first saw one.... five 40's and 2 80's later I finally found this rig in TX and knew it was the perfect start for my build.
The PO had maintained it well and started a mild build - he'd also done the HG at 148k and installed the TransGo tranny kit.
my goals were to create a DD that could do extended trips and yet be comfortable to drive and have a comfy interior.... Sadly the most off-road time this truck has seen so far has been dirt roads and one day at the local park to test flex and function. The lockers engage perfectly and the truck is amazingly smooth, and planted feeling onroad as well.
The rig has always been a SE / Texas truck - no prior damage and NO rust, nor pinstripping....
The build has been open checkbook and short of my "dorkle" I've used mostly the best-of avail parts and OEM for most of the wear items from Beno. it is Fully baselined and needs nothing - I'd happily jump in her and head to Alaska ... compression was checked when they did the injectors and it was 130-135 across the motor.
The rig just turned 220k but looks a few years old on the outside, and almost new inside... with a expensive upgrade list:
A partial build list -most work done in last 15k:
4" Slee coils ( med rear) w/ 10mm pakers aand caster plates plus full SS brakelines
Landtank LCA's - Metaltech adjsutable UCA's plus all bushings
Landtank front DC driveshaft & Custom double double rear Driveshaft
Slee front and rear adjustable Panhards
Swaybar drops and front swaybar disconnects ( LC Phil )
Slee /ADS 2.5" remote resevoir shocks
New powerslot drille/slotted rotors all the way around - new OME calipers and pads as well
Rebuild front end w/ Aisin hubs added
Slee Full skid plate
Fuel Anza Rims / Mickey 315/70/17's MTZ's - less then 2k on setup
4X4 labs dual swing out rear w/ 3 can basket and Ladder
Slee front bumper w/ Warn VR10000 w/ synth and Factor 55 thimble & Slee fairlead
Labrak shortly rack plus Thule bar and labrak adapter for front end to carry kayaks etc
Full cooling system overhaul - new CSF alum radiator, WP, thermo, hoses and breeze clamps
Landtank fan clutch w/ 20k fluid
Fuel injectors rebuilt and EMS SS intake pipe replacing rubber OEM setup plus all gaskets
Replaced PS lines and all vac lines
Dual AGM Dekka Batteries w/ Slee relo kit and Blue sea ACR
New OME steering stab - 555 tie rod ends and Slee relay rod
Custom Depot headlights w/ HID's and blacked out insides plus 100watt highs and slee harness
Kenwood Excelon Nav unit w/ Sirius and backup camera
Kenwood 5 channel amp under drivers seat
Rockford fosgate 6 1/2 components in front doors
Rockford 6 1/2 2 ways in rear doors and Kenwood 10" sub behind rear seats
Scanguage in ashtray location
Gamviti dual battery monitoring LED setup replacing cupholder in dash
SPod 6 switch kit and master panel mounted in center console
USB and 12v acess in center console and rear pass panel - plus hardmount Streamlight w/ charger
1500 volt Invert wired under the passenger seat
37" LED single LED bar for rack
side LED's on rack
Yotateq rear light brackets and LED lights
Extended breather lines
Rosen Visors
WagonGear rear storage lid
4X4 Labs rear drivers side basket
LC Phil Rear passenger mount w/ Viair Compressor & Maglite mounted
over 150 SF of Fatmatt installed on almost every panel and sound dampening rubber matting
fresh OME full carpet kit installed - almost like new
Inno Hex matts on all rows
Cobeau GTSii front seats in black suede ( pending recover)
Fort Knox safe hardmounted in center console
Craft Custom leather / wood steering wheel
Remin Dash wood kit
Vision X 4.5 LED driving lights on Slee bumper
Pfran interior LED's
BIOR side sliders
and many other little things I'm sure I've forgotten....
To be finished or works in progress with parts on hand:
Recovering Corbeau's and OEM cloth rear seats in Toyota Cloth/ velour w/ leather trim
Redo of headliner in matching Suede - replace windshield ( have gasket) and monstaline roof tan
Mount of JDM rear spoiler
I have this work scheduled for mid March with my local shop -
I'm asking 19,800 based on the rig as it is currently -
I will post up a batch of pics to give a sense of the rig but if you have questions or want specific pic/ details feel free to PM me.
I'm happy to deliver the truck within 500 miles of Houston or meet you at the airport, as well as coordinate a PPI if you wish.
side LED's on rack
Rosen Visors
Remin Dash wood kit
BIOR side sliders
