Wanted Horn button pre '72
Perth, Western Australia
Horn Button / Contact Spring / rubber spacer / small spring & brush are needed.
Alternatively may interested in the comp assembly.
FWIW, I ended up having SOR rebuild the seat (plate, brush, spring). They had the rubber spacer and plate too. For the life of t I can't remember the MUD member's name who makes the horn buttons but I'm sure someone else would be able to throw that name up here. Good luck, these can be tough to dig up. Pardion might be able to provide some though!
Thanks Indy & Fix, I have already wrote to Ant yeaterday and awaiting answer.
But that's one half of my problem, I also need the contact spring.
SOR soldered the spring onto the "seat" (#45142 in your pic), and the brush is a bit of metal that sits in the end of the spring. I've been told lots of people simply use the spring from a pen! For a more precise fit you can use McMaster-Carr for the spring.
