Homemade skid plate
FJBen
Northern Colorado
Looking at the flimsy t-case skid, decided I need a bit more. Started with a beefed up version of the same thing. Made out of 3/8" steel. It's going to have support brackets off to the sides as well, just trying to figure out the best way to brace it.
thoughts welcome
pics,
1: side by side and my helper
2: the helper...helping...
3: installed...
Very Cool!
:cheers: :cheers: :cheers:
yup, the bracket is more important than the thickness given the cantilever and mounting setup
It's a very thick plate and I'd like to see another support bracket. This will come into play when you back over obstacles and get hung up on the edge. If you look at Slee's, he has a nice curved lip that prevents getting caught while reversing.
Just my .02 cents.
Ali
If you can angle the bracket a bit to the rear and bolt it as close to the trailing edge as possible, that will take care of not having the curved section on the back, and while in reverse, if you do get hung up, it should slide alog the bracket and then over the plate.
.02
Dan
I've got Slee's skid and you may have the same problem as his - that is; any major size rock pushing on either side will bend/flex/break your bracket. I would suggest making the drain hole twice as large, so when this happens you won't feel the need to get under there and repair it as often.
Just my .02 cents.
Ali
Like Ali said.
very nice start though:beer:
