Hi,
Thought I'd post some info and pics on a rack I built recently for my sis. I don't weld, so it had to be something I could make with "normal" tools. I borrowed a drill press for one step, but a large hand-drill (which can be rented) would work too.
The key to this design is the joint. Once you see how to make this, you'll have lots of options in terms of how many supports, how many cross-bars, length, etc. The joint relies on a recessed hex head cap screw. Once you see how the cap screw works with the square stock, your imagination can take over. Lots of things can be added to this design to make it suit your individual needs.
Materials
Metric socket cap screw + washers and nuts
Cross Pieces - 1" square stock - 50" in length (X's 5 in this case)
Side Pieces - 1 1/2" L stock - 2 @60" each in this case.
5" Wilderness Roof brackets from Spectre Off Road (3 pair for this rack)
http://www.sor.com/sor/partpict.tam...f Racks&descriptionpg.ctx=Page 256 Roof Racks
You can purchase the square stock cut to length. So the only real work is drilling and painting.
I found that the hole in the square stock should be 7/8" in from the end.
Note that the hole in the square stock will go all the way through, but the bottom hole is smaller. The top hole is just big enough to allow the head of the cap screw to fit through, but the bottom hole only allows the shaft of the screw to fit.
Not shown in the pics are drain holes in the bottom of the square cross pieces.
The L stock needs holes that correspond to the square stock holes. Measuring on the inside of the L stock, set them also at 7/8".
The holes in the L stock are only big enough to fit the shaft of the screw.
Time for some pics
Materials
Time for some pics
