Wrenching is not a problem. 12ht is a bit new but seems relatively simple enough
Good luck with your new acquisition. It would be a RHD I suspect? Does it have round headlights
or 4 square? AC? I just put final touches to my intercooler build and GTurbo install. Haven’t run it yet,
ran out of time. February should have it running. 12HT is super motor for where you live cause it
it primo long haul engine, those trips to PG and up north. Easy to work on since very little to do.
Look at condition of the throttle springs, there should be two. They are within a plastic tube,
causes them to corrode and break. Check the wiring on the glow screen, temperamental.
I can give you a source for the throttle springs in Europe. Throttle response is a bit
of an issue, but with the properly operating springs it is a non issue.
They have poor cabin heat from the front heater. Make sure the heater valve under the hood is
in good condition and the adjuster slider is lubricated.
I got more, but when you get into it call me. J
