- Joined
- Dec 8, 2006
- Threads
- 158
- Messages
- 2,974
- Location
- Greenfield, MA
- Website
- thecarpentryway.blogspot.com
- Thread starter
- #1,301
Last couple.
Apparently the TM3 is now allowing the engine to start no problem, but doesn't seem to be humming along quite yet. The wiper motor remains to be solved.
Apparently I need to have defrost capability before I can pass inspection, so i will have to run 5/8" hose to the heater box in the short term until i can get a set of the hard lines or make some up custom if i put in a WVO system at some point (thinking about it).
I swapped out the rear crosspiece for the tray, and with a little fiddling, which included removing the 1/4" shims from the rear cab mounts, i got the sight lines looking pretty reasonable. The front wall of the cab looks close to parallel with the fuel evap. cover, and the deck surface is parallel with the chassis rails directly under the cab. All good.
I will be taking the truck on a shakedown cruise pretty soon, perhaps tomorrow. I have to complete the original importation procedure now, which means i need to drive the truck north about 45 minutes to a place where the Canada Border Services can get a look at the VIN plate, and give me the all-important two stamps on "Form 1". That will be followed by soon after by Provincial inspection at some garage. Then registration and insurance, and license plates.
