HJ45 Engine Cut Off Switch (10 Viewers)
Somerville, TX
Ive been trying to find out for some time now how the 1985 and older HJ's turned off. I've heard that there is a kill switch on some and others you simply remove the key like modern cars. Which one is it? Any advice or info is welcome.
Since the diesel does not rely on electricity to run, cutting it off should not be counted on to stop it. IIRC, My HJ45 had a cable that when pulled cut the fuel to the transfer pump.
You might get a more precise answer in the diesel section.
