I’ve got a 97 and getting an occasional grinding noise coming from somewhere in the front part of the drivetrain. From previous searches I was thinking that it is dry spindle bushings, but the noise goes away when I give it some gas, which I wouldn’t expect??? with spindle bushings? Here are the details:
Where is it coming from: It’s really hard to pinpoint other than the front of the vehicle. I can feel the vibration through the gas pedal and the shifter when it happens.
What does it sound like: kind of like ‘grrrrrrr’ . Sort of like if you tried to shove a manual transmission into gear without using the clutch. It‘s easily audible (not subtle) even over the radio.
How often does it happen: On average about once every 5-10 miles of city driving.
When does it happen: It happens when I’m off the gas, between 10-40mph and going over small bumps on the road. It has never happened on the interstate and I don’t think it’s ever happened when I was on the gas.
What makes it stop: Pressing the gas or waiting a few seconds and it will stop. It’s never lasted more than about 5 seconds.
What doesn’t make it stop: Pressing the brakes has no effect, shifting to neutral has no effect.
Other clues: The birfields were rebuilt about 3K miles ago alone with front wheel bearings. I didn’t do it so I’m unsure about the status of grease in the birfields.
I don’t like the idea of digging into things without a pretty decent shot that I’m going after the correct problem. Has anyone had similiar issues and solved it? Any ideas?
Thanks!
Thanks!
