If you think you are under powered with the 1hdt just up the boost and fuel. Can run 12- 14. Psi without any major problems and the difference in performance is fantastic. I also added water to air inter cooler. I think you need a break down run on your truck before the big trip just tn be sure. And towing my boat at 100 km/h (60 mph) I would get 17ltr per. 100 km. 13.3 mpg. That was prior to extra boost. If you buy the HDJ81 you are putting your trust into the company that is doing all the repairs/maintenance Research them well and good luck Cheers Brian
