Help! Water/electrical damage
Oklahoma
Had some water come in after a car wash and found this connector damaged. Does anyone know where to find the wiring diagram for this? It is inside the passenger side kick panel. One of the male pins broke off and is stuck inside the female side. The blue wire. Made a jumper wire just to see and didn't help. Truck is stuck in limp mode, CEL, Traction, and flashing 4Lo lights on. PO121 throttle position is the code that won't clear. Thanks! 2011 GX460
  • Sad
Reactions: r2m
And to add to Acrad's post, you will probably need to get something to read codes, e.g.: OBDLink MX+ OBD2 Bluetooth Scanner (https://www.amazon.com/gp/product/B07JFRFJG6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 ), TechStream (https://www.amazon.com/gp/product/B07BCNPDDG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 ) or a hand held scanner.
Acrad, myself and others on this forum use the OBDLinnk MX+ and works really well on reading and clearing codes, assuming whatever tripped the code has been corrected. It's also great for keeping tabs on your TPMS for each tires pressure and temperature, along with engine and transmission temperatures and much, much more, all live while you're driving.
