Ok folks, this may get long, but I wouldn’t mind some other opinions on the matter. Hell, just writing out all of the facts may lead myself to the answer.
First, the relevant mods that have been done that involve electrical
- Slee group 31 Upgrade Kit
- Odyssey Extreme Series Battery - 31-PC2150T
- Comeup SEAL GEN2 12.5rs, 12V WINCH
- ARB Twin Compressor with switch mounted
- 10 gauge wire thru passenger side firewall ran to rear for accessories (Fridge)
- Alternator Diode
All of this had been installed for over 6 months for the most part and haven’t had any issues.
About a month ago I had a couple instances where I pushed the button to start the cruiser and failed to start. I always assumed I shifted too soon out of park which seems to stop then ignition process. Shifted back into park and started up no problem.
Two weeks after that My wife let me know that it wouldn’t start while I was away on business. But later it did start. We assumed user error.
A couple weeks ago it failed to start again. This time it seemed stuck in a weird limbo, would start and wouldn’t power down. Lifted the hood to find this weird sound.
Trying to figure out what was going wrong, I started poking around with a multimeter and checking solid connections. What I noticed quickly that the ground wire leading to the winch was oddly heating up. So I disconnected power and finally got the system to shut down. After attempting this startup I forget the exact voltage of the battery but it was sub 12 volts.
I measured the resistance between the positive and negative cables leading to the winch and found there to be some resistance, I think in the 200k ohm range.
SO i charged the battery and added a couple gallons of gas, as I was parked on an incline and figured it wouldn’t hurt since by range was all the way down to 10 miles. After a little while, cruiser started right up.
Drove around for 2 weeks and no more issues. I have noticed the battery usually reads 12.4 after sitting for a little while, and will even go lower once not driven for a while.
I reconnected the winch for 2 days and noticed a similar slowly draining of the battery but didn’t experience any more failures. REally need to test this more, but had to head out on a trip and didn’t need dealing with a problem on the trail.
So...
- Battery voltage drops to 12.2 over the course of a couple days when disconnected from the vehicle.
- The battery is certainly wounded. I have trickle charged it occasionally to give it its proper charging voltage.
- The charging diode helps boost the voltage, but still isn’t ideal. However, It wouldn’t be this bad at holding a charge given these latest two points
- I drive this car maybe 5 miles/day when not using for a trip on weekends. A parasitic drain could be bad enough to not be overcome by minimal alternator activity
- Resistance form the positive and negative winch hookups. Is this normal?
- I first used the winch last November to pull people out in the dunes.
What would you all do next? Safe to assume the failures were from some sort of low voltage cutoff of sorts? It doesn’t seem to be a starter issue, as I do know those exist (I’m at 70,000 miles)
My plan is long term to have a solar panel trickle charging the game at its voltage It likes. BUT, before I install that, I want to get to the bottom of this. Solar at this point would just act as a bandaid I feel.
- Alternator Diode
So...
