Hey guys I'm looking to de-mod return my 93 fzj80 to stock because its more of an overlanding rig and climbing up rocks. I'm moving from 315s to 285s and currently sitting on 2.5" dual rate dobinsons lift. I'm fairly confident I can reuse the shocks but looking to do a stock height spring (Like OME ect) and remove my 2.5" land tank caster brackets. I have a rear tire carrier, stock front bumper and putting the winch inside the front stock bumper (Stuff to be added will be a front bull bar, sliders, & drawers). The roof rack is coming off. Do you have any suggestions or anything to be weary of? I want the ride to be level as this was stink bugging pretty bad the entire time I had it. I'm open to suggestions on stock height springs - I don’t want to keep the lift going to 285. The exact model shocks and springs on the FZJ80 are:
Edit: My contribution to this thread is if your truck is outfitted like mine this is how the lift will look.
- C97-146VT: 2.5" Variable Rate Front Coil Spring Pair (Link)
- C97-147VT: 2.5" Variable Rate Rear Coil Spring Pair (Link)
- GS59-683: Shock Absorber Front 0-3" Lift (Link)
- GS59-682: Shock Absorber Rear 0-3" Lift (Link)
- SD59-824: Steering Damper (Link)
- Landtank 2.5" Caster Correction Brackets (Link)
