Hey. Thought I'd pick a quick easy upgrade and swap out my bump stops and try out a set of front and rear stops from Perry Parts. The front oem bumps were in tight but did come out with relative ease.
The rears were not as forgiving. I made the mistake of rushing , not taking a tire off, and not letting PB soak long enough. I reach up from down below with 1/2 ratchet and proceed to snap 3 of the 4 bolts , doh! I saved the 4th bolt by the time I finally wised up, removed the tire, and took my time. It still came out very slowly and took some in-and-out and lots of pb blasting.
OK so now what? I assume there's a small welded nut in the frame or maybe the frame has threads on it? I can't imagine getting lucky enough to somehow save the nut / threads and back out the bolt. Tomorrow I plan to go to HF and get a corded right angle drill, a s*** load of drill bits, and a handful of M8x1.25 taps. Or will I destroy the M8 and need to go a size up or maybe over to SAE
I don't think there is really any other option unless I have someone weld the originals back in place, which may be my eventual destiny.
The one bolt that actually came out, next to a snapped bolt. I have a decent amount of space and was able to get a center punch in there but its too tight for a normal drill.
