Hi
Just finished my baseline and build spent a fortune on the rig and started going over landing
Over landing basically its 2 or 3 days, 100 miles on highways and country roads from home to the Negev Desert 50 miles on the trail each day with some technical rock crawling and passes and then 100 mails back home
Most of the driving in the desert is allowed only during the day, at night we have to go approved Campgrounds
Now its winter so ambient temp during the day will be 18-24 C (65-75 F) so its cool and nice
I measure engine temp by two ways
1. OBD temp
2. External engine skin temperature
Both measurements coincide with some delay on the external unit
Here is what I found
Miles temp C temp F
50 84 183
60 86 187
70 88 190
80 90 194
If there is hill, it will go 92-93 (198F) and I have seen 95 (203F) for very short time the temp change is fast up and down
Reducing speed will make the engine cooler very fast
This is winter this rig wouldn't survive the spring and summer temps will go up to 104F
This is overheating phenomenon that nobody here knows what to do with it most of old rigs overheat in low speeds not enough wind in the radiator not enough water circulation in low RPM the water pump moves less volume
All the engine cooling system is brand new including oil cooler. And I am using Toyota red
I have read everything on MUD it looks like 1fzfe problem of not enough coolant circulation
The things I do not know
* The position of the hole in the thermostat
Things to do
*Vents on the engine hood
*Blue fan clutch mod but this is negligible at high speed
Things I may do
Engine cooling system flush PO used tap water
i was advised against this!!
Open to any suggestions
1. OBD temp
Miles temp C temp F
50 84 183
60 86 187
70 88 190
80 90 194
Things to do
Things I may do
Very true.
