Help Needed: Trying to Install 2007 LX wheels on 2008 LC
I hate to say that I still havent found hubcentric 10mm spacers to use those beautfful LX470 wheels on my 200 series (to clear the larger brakes).
I'ven been searching on the web every now & then but no luck.
These wheels on mine are from Ultra.
You will need to use either a non-hubcentric 10mm spacer or maybe a 1" (25mm) Wheel adapter (can't say for sure since I don't have a 200). If using the 10mm spacers, make sure there are at least 6 full turns on each lug nut otherwise, you'll need longer studs. I would personally go with wheel adapters over spacers.
So the problem, author describes here means that wheels from 2008 landcruiser have same bolt pattern as 100s but less backspacing, right? I guess I could use 200 wheels on my 100 then.
BTW, can anyone tell the exact stock measurments of 200 wheels pls? width, backspacing, etc..
You can use 20" Land Cruiser/Lexus wheels on the 100 series, se picture.
I guess the 18" wheels also fit, they have the samme backspacing.
Bjørn Erik
Bjørn Erik
Excellent.
