- Thread starter
- #21
Thanks for the ideas guys.
I went out today and got a new coil to try.Maybe not a proper coil? Anyway it made no difference.
I rechecked all gaps and timing - good.
If all else fails I'm going to take the carb off one of my running 2F's and see if that does the trick.If so I can then tackle the carb.
Showing my ignorance - idle solenoid? I hear no clicking,just a motor on the verge of starting.
The plug thing is nagging me.It should be grounded to get a spark.I hold the end of the plug about 1/8" from the block/valve cover and it sparks and arcs to the engine.If I ground the threads of the plug to the block/valve cover I get nothing.
Something wrong with this picture?
I'll try a dizzy ground wire.
Solution for me was a carb clean/rebuild.
How about the idle solenoid? Does it click when you turn it on?
Still sounds electrical to me.
I have never seen a plug that would arc to air.The plug MUST be grounded in order to make a spark.
