My limited mechanical skills have failed to start my truck.
Here's the story.I got the truck,a '73 FJ55,as a non runner.The PO claims that it just died while idling in his driveway some time back.He said that it was as if it ran out of gas ie. no big bang.
Well I got a great deal on it and could use it for parts but why not try to start it first.
Everything looks fine.Oil,rad etc.No obvious signs of abuse or leaks.Set points at .018.Plugs are at about .028.Fuel pump is working - removed line at carb and had someone turn it over.Has spark - removed plug and turned over.Figure the gas in the tank could be old so,as it is being started,I poured a small amount of fresh gas directly into the carb.This fine rig doesn't even act like it wants to start.I did turn the dizzy a few degrees either way during test starts - nothing.
It does have a 2 barrel Rochester carb on it and a recent looking after market coil but everything else looks stock.
Hopefully someone out there can figure out a solution.
Thanks in advance,
Thanks in advance,
is turning it over.
