ok, here's the quick list from the mechanic:
Rust
LHS bullbar
Bonnett
Nose Panel
LHR wheel arch
LHR near lights
LHR window inside
In rear floor and framing
LHR door
RHR door
RHR wheel arch
RHR above lights
RH pillar near driver's seat
RHF door
In floor behind pass seat
I've put up pictures of the rust
here
- RHR tail light cracked (though i think it was just dust)
- Steering joint/knuckle - loose and has play in it
- Front engine pipe cracked to exhaust - fix/replace
- Clutch slave cylinder leaking
- LH engine mount broken + moved
- RH engine mount broken
- Wheel nuts need replacing
- Driver's seat - fix or replace
- Driver's seat belt - replace
oh, and the rear spring shackles need turning
so it looks like i'm up for some serious rust removal. i'd love some suggestions for each of the bits whether to:
1. replace the part
2. cut and fill with bog
3. cut and weld over
4. find other bit from other 40 series and cut and patch
5. scrap the whole thing
6. any other ideas.
