haven't done much research on the mazda.. i know their larger hatch/suv has a turbo on it which can kill it and eats gas.. I do like how they appear to be smiling all the time..
the highlander is great but doesn't get the mileage needed for me. Jenn drives hers daily and i think we're at about 290000 on it?
Yeah i know a bit about the matrix.. it's a corolla so pretty easy to figure out.. One weird issue on the matrix, which i have since figured out is it squeals like a pig in the wind.. the windshield gasket along the A pillar has a slight curve to guide rain down the windshield. Well.. it also acts as a whistle in high wind driving. Annoys Sage and Colin more than me (they drove it back from Kentucky whistling) but i did figure it out with painters tape on a road trip. A touch of black RTV in the channel and voila.. fixed..
YOu know you can also find a prius in that price range.. i have always wanted to try one out but just never jumped.. There is a local place here in kc that redoes the batteries for about $800 ish..
Pretty sure the prius has approx the same size engine as the matrix.
While I would LOVE a TDI. all the research I did led me to the TOo much maint issue.. Timing belts every 60K and some wiring gremlins.
To put it in perspective.. I went from an Acura GSR to the matrix.. while the GSR was a really fun, fast car, the matrix allows me to relax and commute.. Was strange going to an auto but after a while, it is a bit more relaxing in traffic.. not to mention the GSR SUCKED in snow..
I used to own hondas and run them into the 300000+ life.. BUT.. timing belts on honda are a pain and CV joints on hondas go at 125000 and about every 60-80000 after that.. I've not actually had to replace a cv on a toyota yet.. In the lifespan of my accord that was 8 cv joint replacements along with both sides front wheelbearings.. That adds up! The CV joint issue alone is worth a few thousand dollars in the lifespan of the car. more if you pay a shop..
and the matrix 1zzfe has a timing chain, read no replace unless something big..
What I would look for in a daily driver.
Maint intervals.. Timing belt vs chain , How hard are they to replace.. how often, are they an interference engine?
Vtech / VVTI / other do they have known issues, especially with the actuation solenoid?
CV Joint issues.. are they known to go out and how hard are they to replace.
Any known big electrical issues in the forums?
Are they known to burn oil and if so why? can it be fixed.. (which the matrix can I just haven't needed to do it yet)
does it actually get 30mpg normally..
THen the fun part.. Are they comfortable and can they hold a bunch of stuff.. and are they ergonomically correct for sitting in.. Can you strap stuff in the back easily.. are they convenient.. That is what makes a good daily driver. is your coffee cup handy and does it fit..
Go drove that subaru and the matrix.. read the forums.. I am curious what you come up with. I don't think you will go wrong with either.
