Does anyone have experience/an idea how I might reinstall the plugs with rocker shaft in place? The shaft is directly above the plug holes but high enough to make the angle slight. My guess is it depends on the required method to install the plugs. Does one drive the plugs from the edge working around, by driving the center, or by precision driving while matching the outside edge with something?Removed side inspection cover and freeze plugs looked intact. Added water to radiator and water started flowing down out of pushrod holes from above. Removed valve cover to observe the first three (in row from front to back) freeze plugs lying along side their holes as pictured below. Plugs, gasket, and FIPG on order from Mr. T.
I was aware of a loan a tool for plug installation. Many videos just use a socket. Is there a loan a tool option to pressure test? Thanks
