Hello
Been an interesting couple of weeks. I apologize for the length of this, so i appreciate it if you make it through this and can offer up some insight.
2002 LX with 171k miles. My guess is starter is original (alternator was original) and i don't see records of it, and records are solid except for about 157k to 167k.
Replaced my heater t's, hoses, clamps 3 weeks ago without issue. I got the wires in the back of the engine a little wet when i cut the hose, but wiped it down and didn't start it for a good 45 mins to an hour. I only mention this to be thorough. My mechanic thinks i am being paranoid and that it's unrelated.
2 days later I'm making a home depot run and the battery light flashes, radio goes on/off, i'm thinking i shorted wires from the heater t job or something. I get it towed to my mechanic and he confirms the alternator went out. Great. Got that replaced. Was too busy to do it myself. I noticed the radio go on/off a couple times the day before, but i thought it was just my music cutting out. Other than that, really no obvious sign the alternator was on its way out.
About a week later (today) I've driven the truck to/from work a few times (40 mile round trips) and took it on another 40 mile run yesterday after changing diffs and t-case fluids. Ran great!
I go to start it today to do ahc flush/transmission drain/fill, and i get 2 clicks, but truck doesn't start. Try it again and don't hear any clicking this time so i'm thinking starter. Again, i really didn't notice this on its way out. It has always started without issue.
Call up my mechanic, we both agree it doesn't seem to be battery (lights are super bright, don't dim with key turning). I've had a dead battery about 6 months ago, but haven't had any issues afterwards (my fault for letting it drain).
I saw this thread and checked my EFI fuse post #20: 2002 LC100 - Not Starting... ??? Fuel Pump ??? ... my check engine light turns on and both my EFI fuse and relay look good so i think i've ruled this out.
So that's where i'm at. I saw this youtube video where it jumps the starter using the starter relay:
My question is...has anyone had any luck with that? Any risk to doing this? Any extra detail you could offer for this specific relay? Unfortunately i can't just bang on the starter.
Another thing i read on here is it could be related to a ground that's not connected or something along the lines of that. How would i test that?
Thanks for reading.
Edit: i missed this thread ( Please tell me it's not the starter again... ), which has me leaning towards dead starter. will double check terminals tomorrow, but those looked pretty good when i looked earlier. I don't think it's an immobilizer issue ( My immobilizer fix ) because it doesn't crank. That thread looks like it answers my question on how to jump the starter using the relay, though.
Thanks for reading.
