Hi all.
My daily driver wouldn't crank today.
Summary of vehicle:
2003 UZJ100R, V8 petrol with 5 speed auto transmission.
The engine is a 2UZ-Fe 4.7ltr V8.
It has 240,000kms on the clock.
I've only had it since the start of this year, and I suspect the previous owner spent a lot of time on the beach with it, as it has some rust issues.
Summary of fault:
The car won't start - it won't crank.
Error codes P0335 and P0340
I drove it this morning with no issues, then came home and parked it for a few hours.
Then I went to start it, and it won't crank.
All the lights come on, radio, doors, lights, etc work, and the accessories turn off as they should when I attempt to crank it, but no crank.
I can also hear the fuel pump running when I try to start it.
Just no cranking.
I replaced the battery when I got it, earlier this year, with a brand new battery to suit it.
The battery indicator is green, indicating its charged, and the dash battery meter indicates its just over 14v, where it normally is.
This is the first time this issue has occurred with this car.
What I've tried:
Cannot check much as I don't have a multimeter - but I will bring one home from work tomorrow, but I suspect battery is good, as is the ground - which I checked a few weeks ago.
I thought at first it might be an issue with the park position sensor - or whatever its called - ie, the system may think its not actually in park, when it was... but I thought I'd hook up my scancode reader.
The scancode reader is reporting codes P0335 and P0340, Crankshaft and camshaft position sensor respectively.
I cleared the codes, disconnected the battery for 15 mins, then reconnected it with the same results.
I'm assuming the crank sensor is the culprit, as it drove home and I parked it fine, and, after reading a few posts, it seems to indicate if it was the cam sensor the car would stop immediately, whereas a crank sensor fault would allow the car to continue to run until it was turned off, and then would not start.
Has anyone come across this issue before?
I searched the 100 series forums on here, and only came up with three results searching "P0335 P0340" (without the quotes), none of which provided much information.
Is it hard to get to the crank sensor connector to test?
I think its under the plastic 'bash' plate, for want of a better word, but not entirely sure as yet.
Any other suggestion?
I plan on checking the resistance of the two contacts on the crankshaft position sensor once I get the multimeter from work...
As its my daily driver, I need to get it up and running asap....any help greatly appreciated.
Summary of vehicle:
Summary of fault:
Just no cranking.
What I've tried:
