My problem with headers is that once the temperature gets below 75 degrees outside, especially if there is a high dew point or heavy humidity, it takes my cruiser a very long time to warm up to a temperature that allows the engine to run strong without the common cold engine symptoms.
Once it hits 75 degrees, I need to close off the cold air intake on my filter housing and have it suck from above the manifold. Unfortunately, since it takes a long time to heat up, the manifold doesn't start to push warm air into the carb unless I get to operating temperature to burn off any moisture and then drive for at least 5 minutes to get out the chills out of the engine. Doing this does help the engine warm up faster . . . sucking air from the manifold, but then it takes power since it will eventually start sucking warm air into the carb to loose power. (Cold air intake makes better power)
Anything to speed up the process would improve the time I have to first start my cruiser, go back inside, finish my coffee, and morning constitution before I can drive down the street. The filter housing is meant to be closed when things are frozen outside, not when a light sweatshirt is needed for a few minutes in the morning.
The kits look like they would be easy enough to fabricate for the 2F since it would just be a plate that is cut into a bowl with ports. But the F needs a plate that is cut into channels. I don’t have the tools to do this. If someone could make one like the kit I am looking for, I would rather pay a Mudder than a company.
