- Thread starter
- #21
How hard was it to get in behind Relay Block #1? I am looking at using the empty relay socket on the bottom right for the heater elements (I already have a relay that fits it). It's still too cold to be pulling on wires and plastic connectors though.
Not too bad - I was in and out in an hour. It is a tangle of wires and in undoing them you need to take the time to put them back neatly so the kick panel goes back in nicely. It's a great time to do the Pin7 mod - but I see you have already done it. There is a factory ground point behind the kick panel as well which made the grounding easy. The relay block unbolts with two nuts and comes out easy for access.
