Heard a POP, and things got worse
Buy the beer and pizza for the HAMOM. It's cheaper than paying someone and you will learn a LOT in the process. I just rebuilt my steering box and replaced by power steering pump. I can rebuild a steering box in about two hours now and that includes dealing with all the fluids that come out.
I've done PHH, EGR delete, HVAC, and body lift by myself. It always took me a long time because I learned as I disassembled and replaced components.
BTW, I have Gates green stripe and constant tension clamps for the PHH. $15 for the kit.
I saw the vents at the bottom and thought this was a TT Z. Still a beautiful car.
Oh that's right, I swapped the front bumper cover with the one from a JDM clip my brother had for his TT. I didn't like the N/A front bumper cover that looks like a goofy smile.
Since I just figured out how to successfully append images: Here she blows (literally):
AF1QipPCVsPI_LqY3CZ_ST9kg5h-K6pNzi5Ks0fVsh3c
Plus one to getting some fogging oil in the cylinders.
have a small Hamom to get the head off.
Then schedule a Hamom to put it back together after you get the head looked at and parts on site
Like you see, it is not about how new you are or how much these people like to wrench. It is about how bad they want to get away from their wifes!!!!!!!!
Ooh I'm gonna tell.
You forgot :beer::beer::beer::beer::beer::beer::beer::beer::beer:
The best $20.00 you will spend this holiday season will be to purchase a silver star here on ih8mud. That will allow you to upload more pics, and allow you to enter the inner scrotum (or sanctum, i forget which).
I'm in the middle of a HG swap on one of my 80s. I've amassed just about everything I need to do the job. My replacement head is at the shop getting some love. I'll figure out my next steps once i get the call saying its ready (hamom vs shopping it out, i go back n forth on that).
Some handy tips from someone who is there...
Get the full OEM head gasket kit. I think I ordered mine thru macgregor toyota in virginia. Beno is also a great source for parts (he was out of pocket when I ordered mine). It will come with pretty much every gasket and seal you will need to do what you need to do.
Things to do while youre there (in addition to the HG).
Press in new spark plug seals into the valve cover. They come in the kit, and the valve cover will be off. Decide if you wanna get all crazy and clean/prep/paint, or go full in idiot and polish said valve cover.
Pesky Heater Hose, either replace the small 2 inch piece, or run the bypass. Search is your friend. Use good constant torque clamps.
Replace all of the small heater hoses on the back of the firewall. There is one that is next to impossible to reach while the head is on. Take the opportunity to do them all. Again, use good constant torque clamps (they are avail at napa, along with their Yellow Stripe hose, comparible to Gates Green Stripe). There is a hose with a small 90 degree bend on the passenger side firewall that is smaller than the other hoses. Carquest/Advance Auto parts B87310 hose to go from the T fitting down to the firewall. Its slightly smaller than the 5/8 hose
Heater Control Valve- top of firewall above the head where the coolant lines all converge. Thats 20+ year old plastic, and it is brittle.
Oil Cooler gasket (under the exhaust manifold)
Fuel Filter (under the intake manifold)
Oil Pump cover seal, main crank seal. A guy on mud sells torx head screws to replace the phillips head screws on the oil pump cover seal. Get a 5 pack of GOOD quality #3 phillips bits, PB Blaster, and heat to remote them. Learn a new language when one of those strips or breaks. ;) I've got the dow/corning grease for the new oring you can use.
Replace the distributor oring.
Alt belt pulley and aircon tensioning pulley.
Drive belts (Use toyota oem belts)
OEM thermostat and gasket.
New Denso plugs.
PCV valve and grommet.
Radiator hoses if they look old or feel brittle.
Order a starter rebuild kit (contacts and plunger), and rebuild the starter. Will take longer to unbolt and rebolt the starter than it will to rebuild it. Also, you gain previous hand room when doing the PHH by yanking the starter.
If youre feelin really randy and want to spend more of the money youll save by doing this via HAMOM/yourself, get an Aisin water pump and fan clutch. if you still have money leftover, splurge for a new radiator. get the oem one that is for a 93 or 94. all metal, no plastic. A less expensive option is a denso radiator. Stay away from Koyo and noname ones.
Rather than risk head bolts that are iffy, im installing ARP studs on mine. They were less than new head bolts, and arent torque to yield. (I did this because @Rice is going to want to buy my 80 series and boost it ;) )
Once my head swap is done, I'll make you a sweet deal on my old head (assuming its not cracked or warped all wonky). That will further lessen your cost.
good write Up.
a couple other things to think about.
you might want to consider replacing the vacuum hoses on the under side of the intake while you have it off.
ohm out you plug wires and coil wire, anything near or above 25k ohms is bad.
inspect rotor and cap.
on a side note:
do we as a club have a quantity of valve shims we can gather and share for doing adjustments.
I just ordered a set of denso plug wires for 52.00 shipped. the nkgs that the po had on there showed signs of friction and heat, and a touch of arcing
Had a long talk with the wife yesterday about next steps and she asked when I would realistically get time to do a HAMOM, as I have missed two school events this holiday season to work. Even with our heat going out, termite treatment and other expenses over the past three weeks she supports the s hop doing the HG. I would like to HAMOM an axle job and other maintenance job (many of which mentioned in this thread) once I get the truck back.
A decision we can all relate to and respect. Suggest you leave the timing chain in place. However .... you would like to make sure the shop decks that head when they pull it off rather than simply slapping a new HG on and calling it good.
Understand, we are all family here. When if you need something just ask.
This family just has an above average number of the crazy uncles that like to go around lighting farts on fire and other fun things
. . putting it nicely - I could add a few other "crazy uncle" items to the list LOL :)
HEY!! I resemble that remark. But all joking aside, PO you fell into one of the most selfless groups of people I've had the pleasure to be associated with. Several of them are more than capable of running a shop. Take them up on the offer of a HAMON when you can, you will be surprised.
You don't want my advise on what to do, it would involve fabricating new motor mounts ;)
Speaking of crazy uncles, every time I read this thread's title I think of how I wake up and get out of bed every morning.
Do you mind sending info for tomorrow morning to my phone as s text: nine 1nine-six3two-7ninetwothree. ?
Trust me that's not asking a lot of this group.
We swapped Frame & Bodies one weekend during a hamon
Took out of gas engine and converted it to diesel engine another weekend.
Surely we can do a head gasket without even sweating.
Wasn't going to do a hamon. But I'm going to go through my front axle here in a couple weeks. You're welcome to come watch, help, take notes, whatever
