anything to fix the low beams is welcome. I questioned whether mine were even on last time it was dark. Looking forward to this upgrade.
Finished up the cree Philips hikari update. Drls are not working. They do flash every couple min, but don't stay on.
Contacting hikari to see if they can address.
I just did the Hikari low beams a few weeks ago. Like EJC, I’m not completely convinced it was an upgrade in my case, but the jury’s still out as I’ve only used them a few times.
Note that I upgraded my low beams from Philips X-tremeVision halogen bulbs, which were most definitely an upgrade from the OE bulb in brightness and fidelity. Also, know that I already previously had 7200lumen H11 6k LEDs in my fog light positions. I really enjoyed this combination as the fogs were extremely bright, sharp, and wide to augment the halogen low beams.
Observations:
1) Hikari LEDS are bright, but I don’t think the color temperature is working as well for my particular situation. Because I also have 6k LEDS in the fog position, both lights are bright the same focused spectrum. This seems to cast a single narrow color pallet on everything that was illuminated. Versus the configuration I had before (LED fogs, halogen low beams), that rendered everything more vividly across the color pallet. Another way to say it is there low color fidelity/contrast in the illuminated objects.
2) The spread and cut-off are good. I didn’t have to adjust my light fixture down at all.
3) The illumination is not as even as the halogen as I can see the subtle hotspots and shadows in the light pattern, I think from the individual LED elements.
I may very well go back to my previous setup of halogen low beams and LED fogs. That setup worked exceedingly well. And I know that the low beams won’t fog or ice over in the cold when I go visit snow country in the winter. As both the fogs and low beams use H11 bulbs, you guys might also want to try mixing things around between the two.
^^^thanks for the honest report.
BTW, is this what you had?
https://www.amazon.com/Philips-Xenon-X-tremeVision-Light-85122XVS1/dp/B009HL9L4O/?tag=ihco-20
Good post. You mentioned you may go back to halogen low beams. Did the Philips X-tremeVision bulbs turn on along with the DRLs?
The stock halogens are just too dim IMHO and I am still seeking an upgrade, but I'm hearing reports those who upgraded to Hikari's have issues with DRLs not turning on, which would be a negative for me.
I was wondering if Hikaris come in a 4000-5000K spectrum? I find the 6000K to be little too blue for my taste.
Hikari has stated they will only be producing their bulbs in 6000K color. There are other LED options available, and in a lower color spectrum, but all the research results I've found point to quality, function, or reliability issues with most of the offerings out there. 6000K seems to be the "standard" now.
In my case, I was very close to paying the money to upgrade the HID low beams in both my '07 LX470 and '11 LX570 (in my case GTR HID product with Philips HID bulbs). In retrospect, probably a much more proven solution (albeit some modification being necessary to the caps) and also a much more expensive solution for a quality kit than just a bulb swap). If the Hikaris don't work out, I may end up going that direction.
For now, I'm very satisfied with the performance of the Philips Hikaris in the low, high, and fog positions. The longer term evaluation to prove out bulb life is the remaining issue for me. Losing the DRL function hasn't been a factor for me.
One other thing I'll pass on to the Group: the 9005 Xtreme White Plus PIAA's that I've been running in my 2011 LX, 2007 LX, and 2007 LC for > 7 years don't really "like" the DRL reduced power. I've been getting somewhere around 12-14 months of life out the 9005 PIAAs before they burn out. The bulb color has a black color once they burn out. I've ordered some of the new Philips Extreme Halogens to test in my '75, '95, and '07s once my PIAA stock is depleted. I'm hearing, however, that they are similar in brightness/performance but slightly lower color temperature than the PIAA Xtreme White bulbs.
Hope this helps...
Hikari was not helpful on advice to fix my DRL flicker on the high beam. This was the Cree based HB3. Today's my last day to return so I'm going to get a move on and get these shipped back.
Reading around the flicker is due to low voltage; I don't think a resistor would fix that (even further voltage drop). There are some capacitor based solutions, but I don't think they have the wattage necessary. All this on a quick read, and figure I can research further after return and reorder if necessary. I really don't use the high beams much, but I do LOVE to leave my lights on auto, and can't do with the flicker (which happens in 'off' and auto).
So there it is.
Sorry this isn’t working out. What year is your LX? Maybe a difference between years!
