Headlight Plug (1 Viewer)
Im rewiring my 1969 40 right now the plug that plugs into the back of the headlight has three wires one is ground, on the switch it also says "pass" and "drive". Which is the high beam and which is the low beam?????
-Thanks
pass is high, drive is low....guessing, but sounds right.
You could always hook up with some household wire twist locks and test real quick....I do that all the time when I'm not sure on a connection...or just a touch of electrical tape to protect the twisted wires.
Just wire them (left and Right) the same if it is not correct you should be able to reverse them at the switch, or slide them out of the connector by sliding something thin in next to the female connector to push the catch over to slide the wire out.
