Need some headlight help here please.
Got a 93 HZJ75 here at my place for a few things to be gone thru / fixed. Got everything except for the drivers side lowbeam working. The highbeam works just fine. I have no wiring diagram for this truck but have tried to chase wires with no luck. I chased them from the plug at the light back to the firewall and nothing wrong that i could see. I do know it is not the light itself as i have tried numerous lights i had around here, and they all worked on the passenger side.
It has no fuse box cover but i was able to find the 2 fuses for the headlights and both tested fine both in and out of the truck. I can hear the relay coming on under the dash.
I did take the light switch out completely and found a wire just hanging on so i resoldiered it back on hoping that was it but alas, it was not the fix i was looking for.
One last question here.
Where is the body ground normally located at on this thing ? Found / got the one from the battery to the engine, and the starter to the frame, but never found one to the tub itself, so i put one from the battery to the tub, and the wipers run much better now.
Thanks for any / all help.
