Headlight help, maybe replacement.
Wyoming
Decided to remove the rats nest of harness that came with the ARB solis lights and wire it up directly to my Switchpro. That part went smoothly, but I’ve found my driver brights are disconnected- first photo. Second photo is I think the other connector for the brights on the right with a Y in the wiring right next the factory light connector. Other end of the Y has a white connector that doesn’t look factory, though the Y in the wiring does. Any idea what that white connector is?
One of the pins has been pull out of the black light connector in the second pic, I hope I can repair that, if not what is the best replacement headlight available?
I’ve got to remove my ARB bumper I guess to pull this light out to take a look at the back and see if I can fix it.
Yeah, so the Solis harness uses that white connector which, if I remember correctly, t-s off of a pigtail that goes between your high beam connectors. The Idea being that if your arb switch is active, your solis lights come on with the factory hi beams. You should be able to download the wiring diagram/instructions from arb.
Thanks, I thought it might be something like that but I couldn’t find any instructions on arbs website. I’ll email them.
