Hello the 40/55 forum. After talking to a few FJ40 owners, it is apparent that Toyota didn't do any better job with your headlight wiring than with the wiring in the FJ60 and FJ62s--in fact, yours is probably worse. If your headlights are yellow and dim, you know what I am talking about. I have been building headlight harnesses for FJ60s and FJ62s to either make the stock sealed beam headlights much brighter, or enable the use of higher wattage H4 upgrade headlights. I am planning on also building a harness for the FJ40.
The stock FJ40 wiring has one fuse for all the headlights. So if the fuse blows, you will be driving in the dark. I can build a harness (see schematic below) that is plug and play that has separate fuses for the HI and LO Beams. So if one of the headlight fuses blow, you would still have either HI or LO beam, which is an increase in the safety margin over stock. I could also build a harness that is fused right and left side, so if a fuse blows, you will still have HI and LO beam, but only on one side. This is the safest configuration, but would not quite be plug and play. It would require one wire to be connected to the headlight switch or the HI/LO Beam switch, whichever is more convenient.
So my poll is to see which option you would prefer. I realize that you also have other wiring options, but my harnesses are unique in that they can also come with additional capability to control other Auxiliary circuits like fog lights, driving lights, etc that will reduce fuse and relay sprawl in your engine compartment. (See my sig line)
You could also build you own harness from my schematic if you like.
