Head unit parking brake positive wire trigger location (13 Viewers)
The Last Best Place
Seems like most head units use a negative ground on the head unit for the parking brake trigger but mine needs a positive wire trigger. Scoured threads on head units but not finding the answer to my question for the 97. Thanks in advance!
Out of curiosity, why would a head unit unit need to know that the parking brake was applied (or not)?
Yeah, the 80 has a ground switch on the e-brake. Worst case, you could do it with a relay. Feed the relay with key switched 12+ to one side of both the coil (pin 85) and switch (pin 30) of the relay, splice the other side of the relay coil (pin 86) in with the wire feeding the e-brake swtich so that it gets ground when activated, now the normally open contact (pin 87) for your relay has 12v+ when you pull the brake.
I'm with @Irish Reiver though... what the hell does it care if you're parked? The only thing I could see that being for, is if it disables certain functions when you're driving, which would annoy the crap out of me.
Sounds like flawed logic. 🙄
A lot of the newer units have a smart logic that won’t allow you to straight wire a negative trigger to ground. They have a smart logic that needs to see the parking brake working. So, I’m wanting to find the positive side of the circuit without adding more stuff like a relay if possible to avoid issues. But yes, it’s required for satnav, settings, etc
That would be enough to get me to return it!
The wiring diagram is available in the resource section, but I'll save you some trouble: the hot side of the circuit is hot all the time, the switch is on the ground. You need a relay to get a hot wire that switches.
So, you're saying the wire going in to the switch is hot? Because I put my multimeter on it and couldn't get 12 volts. I can check again. The brake light does light up on the dash.
I mean... Download the wiring diagram and look for yourself. Pretty much all of the gauge cluster has a common 12v source. It feeds the BRAKE dash light, then has two possible grounds: the e-brake switch and the warning sensor for low fluid.
