Temporary Washer Repair
Well I gotta tell yah when I get something going I just can not put it to bed...:whoops:
SO to continue --
I was looking at the washer motor casing "empty" cause I took it all apart & cleaned it out.
I had a look in my junk pile and found an old no name electric motor in it... You guessed it-- I pulled it apart...Guess what I was able with some work, to get the Magnets out and try them in the original washer motor housing....OHHH!!! they fit..
I could still see where the original magnets had been fastened in the old case, cleaned it up some more and glued the new magnets into the old washer motor case..
I still had the old armature so I started cleaning it up..I got it cleaned up enough to try fitting it back into the old case, to make sure it didn't hit the new magnets.. It didn't hit so I cleaned it up completely( the best I could with limited tools) and hoped it would still function.
The oil light bearings (x2) in the motor were also good so I soaked them in oil while I worked on the Old brush mount..This is all one piece. But mine had broke..
I'm tellin you the rust in this motor when I took it apart was just unbelievable.. Most of the problem in the motor other than the original magnets turning to poweder was that the brush springs had rusted completely away. They are used to keep tension on the brushes so they stay in contact with the armature..
Anyway I got the brush holders fixed (there is also a thermal breaker in this motor more about this later..) Then started fitting the original brushes. One slid right in the other was not so lucky.. I had to work on the holder some more to get it to move freely .. but got it done.
The next couple of hours was spent looking all over the house for a couple of springs that would be suitable for putting tension on the brushes.. If found some in an old toy train locamotive..So I scavanged those and used em..
Now it was time to see if this washer motor was gona run or not..
Got the armature installed with brushes resting on the armature and got the housing back on..Spun the shaft up with me electric drill. I also had a volt meter on the hook up connections hoping that it would read something once I started the drill which would also help seat the brushes on the armature.. Once I started the drill the volt meter did show some voltage which told me the armature was still good. I let it run on the drill for a few minutes...
Then the big test!!!!
I hooked the motor up to a power supply .. turned it on and watched to motor smoke.....
Remember that thermal breaker I mention earlier??
Well it was doing the smoking.. I got out my soldering gun and silver solder.. YEP I buy passed that sucker...
Put the motor back together again put the power to it --- what a sound weeeeeeerrrrrrrr IT WORKED!!!!!!
Made sure everythig was sealed up put the pump back on the motor and put the power to it again.. weeeeerrrrrr IT WORKED..
REinstalled the assembly back into the washer tank, put some water in, took it out to the truck, hooked up the power.
Put the key in the ignition turned it on, turned on the lights pulled back on the washer lever.. windshield washer worked BUT SO DID MY HEAD LIGHT WASHER.........Reinstalled in truck tested and worked..
I gotta tell you this was no small job. You would think because the motor was small the job to fix it would be too. If you think that try about 10 hours give or take a few minutes.. how ever long it takes to drink beer take that time off per beer you see. laf, laf
The stuff in this motor is small and I was using one of those magnifier lamps to see what I was doing..also no real tools for the job.
Now If I can find a new one this will make an exellent spare..
This is a large post but for those who read it I hope you enjoyed it..
