Hi All,
Just installed a set of Depo headlamps in my 1994 JDM HDJ81. Works great.
The OE harness switches the filaments on the H4 bulb for hi/lo. The OE setup is with fogs in the other sockets.
So, I want to do a few of things:
So, does anyone know where I can get the wiring diagram that will show the OE relay setup for the hi/lo H4 and fog (H3?) If not, how about some suggestions from someone who's done this, before, to get me on the right track?
Thank you,
A.
- Setup the currently unused H1 to come on with the hi beams, which will likely require a new harness and relay triggered off the gate or output of the OE relay that drives the H4s.
- Use the OE dash control for the fog lamp circuit to power my LED aux lights, but I also want them to only be energized with the high-beams are on.
Thank you,
A.
