Still trying to figure the smoke from my 1HD-T. I'm burning a liter of oil every 500K. Lots of smoke. It doesn't look blue but must be. Its got to be the carbon seal in the turbo. Getting poor power and gas mileage is up and down.
Is it easy to pull the turbo to get it to a rebuilt shop?
I'm going to replace the rod bearings at the same time. Is there anything I should know when changing the bearing. Is it easy as everyone says?
Thanks,
Peter
I doubt it's a turbo seal.
Turbo seals on a diesel leak to the inside, they let more air and exhaust into the centre bearing housing which goes out the drain to the crank-case. For a turbo seal to leak that much the bearings would have to be shot and you'll be running oil straight through your intake manifold.
Have you done a compression check? What are the valve seals like?
