crusher said:
i am trying to picture this in my early morning head, i just can not see how the hub bearing can have anything to do with the center unit since the center unit is a completely seperate beast conneceted by the shaft...
Harveya said that he's presuming the pinion bearing are shot from the noise he's hearing. I'm not that experienced, but I've been floating around the 80's board for a while and I've yet to hear of an 80 with a blown pinion. It can happen, but it doen't seem too frequent. Weird noises are usually due to u-joints (grrr/vibration), birfields (clicking), or in my case hub bearings (grrr).
An easy way to determine if the pinion bearing is shot is to disconnect the driveshaft and move the pinion flange. There should be no movement in / out or side to side. You can do the same for the x-fre case out put, although there is some movement because it uses needle bearings (IIRC). Read
here page 2
Noise is a very difficult way to diagnose a problem in the drivetrain / running gear, just ask Romer (Ken) or PowerPig (Robbie) on the 80's forum.
What type of noise are you getting from the front?
My noise was a
GRRR and is sounded like a WWII plane flying overhead. I was in need of an axle rebuild because both fr & rr diff. gear oil was contaminated with knuckle grease. The mixed grease / oil was oozing past the felt wipers on the back of the steering knuckle.
The lack of preload on the hubs was what I found when I tore into the axle. In the front the PS hub oil seal was gone (oozing grease/oil) and the DS hub had no preload and had axial (in/out) movement. In the rear it was the same thing, 1 failed oil seal and one hub with no preload.
I'm not sure if this was work done by the PO, but I think it had never been done. I think a Birfield repack / axle rebuild is due every 60,000 miles. There's tons of info on driveline noises in the 80's forum. If I were you I would only post engine questions in the international / diesel forum. Everything else should go in the 80's forum. There are a lot of very very technical people to help you out.
Alex
