Indestructible 47
thanks mate, sounds easier than the 12h-t into a 40 which i didCheers mate.
No problems with the engine swap itself really, pretty much bolt in place. The only mods required to get a running / driving 1hdt conversion (from 1hz) would be the air intake pipe to turbo from air filter box (using airbox lid from a 1hdt vehicle is easiest) running a hose for brake booster from vacuum pump and exhaust from turbo back (could use standard exhaust and modify to fit turbo but wouldn't recommend it)
Use 1hz flywheel and clutch (or 1hdt flywheel and Isuzu clutch plate like I have) if using 1hz gearbox
