Speaking of bodgie work,
@Ryan v replace yer belts too. Stating the obvi, but you've got miss-match belts too...one old, one newish, and that ain't right, does your rig squeal? Also, those ain't OEM belts either, find a set of those. (OEM belts don't have the notches) You'll have them off to do this job anyway.
PRO-TIP #3
RE-texaz know how video.
Having gone through the fun I had with my crank bolt, and having to pull out the radiator out late in the game...Honestly, were I to do it again, I'd start by pulling the rad right from the start. it's 30 mins extra to pull it out and about 15% more messy, and a 1
job.
It is the one part of that video that makes me cringe, and face palm, I don't know why he didn't pull the rad when he broke the tip off in the cover screw....
Side benefits of doing it: an extra six inches of work space which is HUGE and allows you better access to the pump cover screws and a lower chance of stripping them, zero chance of shearing that little nipple on the top of the radiator with a breaker bar or contorting yourself in there to get to the other bits, and zero chance of damaging the fins and ruining your rad.
other pro tip: don't use a standard #3 phillips bit on the pump cover screws...Either find a JIS #3 driver or I've found the Makita Impact Gold #3 bits are a really good approximation of the JIS bits (they might even be JIS). Standard US #3 phillips bits will strip those pump cover screws faster than you can imagine. Then replace OEMs screw with Hex head screws...avail around here somewhere.
And ... ha...i'm not a pro, so shouldn't be implying those are pro-tips...I'm def learning the rig though.
