Ham antenna suggestions (1 Viewer)
Mace
rock scientist..
Staff member
s-Moderator
Moderator
Las Vegas
So I picked up a Kenwood TM-271a over the weekend and am working on getting my ham license.
This radio will be mounted in the 60. I have a roof top tent and a roof rack so mounting the antenna on the roof is not likely a functional setup (unfortunate, but that is a major caveat, no big ground plane). Mount will either be front bumper/hood or on the rear bumper/liftgate.
Ideas on a good inexpensive (yeah, I know you get what you pay for but there are better deals out there) antenna for it?
Thanks!
Mace
Do you have a spot on front or side of roof rack that tent does not hit, to use a mount that clamps to rack?
The hood mount gives a bit of ground plane.
Roof rack is not always on, and I have a couple different racks that get used. I'd like a mount that is not centered around a roof rack.
A half wavelength (on 2m) does not need a ground plane, or a ground for that matter (other than the coax shield grounding to the radio chassis). It operates fine.
I had my Diamond 770 mounted on a roof rack with zero continuity with the cab, and it was mounted over the fiberglass portion of my 88 4Runner
Do you have a custom made bumper? ARB's have some tabs for antenna mounts.
If not, maybe an engine hood setup with a metal mount.
Everything on my 60 is custom ;)
Attatching the antenna to any part is not complex. I'm just looking for the "best" location. Given that I'm not going to mount it to the roof. It seems that a fender/hood seam mount is one of the current best choices with a 1/2 wavelength antenna.
Some people chose the middle of the hood. In this case a magnet mount would be indicated. If you can stand driving with an antenna flopping around in front of you, that's a better way to go since you can take advantage of the second best option in terms of ground plane.
One of the other options would be a window mount on the sides, but that would be fairly vulnerable.. Not sure I want a mag mount. I have not heard good things with them..
Larsen makes a good basic 1/2-wave 2M antenna; have had one on my 40 for years and it has always worked well.
Larsen Amateur Mobile Antennas NMO 440B
The second row on that page are the 1/2-waves.
Diamond K400c hatch lid mount. Not cheap at $75, but I've used and abused two of them. One ham and one CB mounted near the top/side of my rear hatch. I run a Comet SBB-1, small flexible dual band antenna for offroad and a much taller Comet SBB-7 on road. The SBB-1 runs about $40.
Stolen from different forums:
"1 - A 3/4 wave antenna is going to have a higher angle of radiation than a 1/4 wave antenna
2 - A 3/4 wave antenna does have gain in comparison to a 1/4 wave antenna - but, at a higher angle of radiation. The pattern begins to break up just above 5/8 wave - so, 5/8 wave is going to give you the best combination of gain and angle of radiation.
3 - 70cm operation lends itself well to urban settings, where the signals can "bounce" off nearby buildings and such; so, the higher angle of radiation of a 3/4 wave antenna on 70cm (1/4 wave on 2M) works just fine (eliminating the need to seek the lower angle of radiation of a 5/8 wave antenna for 70cm). But, generally, a 1/4 wave antenna on 70cm will outperform a 3/4 wave antenna, despite the gain of the 3/4 wave antenna (this is from experience of side by side testing of a dual band 2M/70cm magmount mobile and a 1/4 wave 70cm magmount mobile)."
Re: 1/4 Wave vs. 5/8 Wave Mobile Antennas for 2-Meter & 70-CM Usage?
"1/4 wave is good for foothills/mountain/canyons, poor flat land distance.
5/8 wave is good for foothills, marginal mountain/canyon, & moderate flat land.
1/2 wave is moderate foothill, poor mountain/canyon, best flat land distance."
2m/70cm mobile antenna
1/4, 1/2, 5/8 wave?? - The RadioReference.com Forums
I have a Larson 5/8 wave (nmo, coil type) and a (really small!) Laird 1/4 wave (nmo, non coil)
I can't tell the difference between the two when using. I just got the 1/4 wave not too long ago so I have some further testing to perform, but my radio guy swept the antenna and performed a few other in-line tests with it and was quite impressed. It's about the size of a normal FM radio antenna.
I'm partial to the Diamond K400SNMO Trunk/Hatchback Mount. I've had one on both my 80 Series and they work well on a 60. For a wagon you'll need an 8 or 10' RG316 SMA-F to SMA-M extension cable to make it to the dash.
The type of antenna you get will likely depend on the terrain you encounter. If you wheel in the trees then I like the Larson 150. It's a SS whip that can really take a beating in the woods, but it will go off axis on the highway. If you're always in the clear, I had great luck with the Diamond NR770HBNMO. It's a dual band and gets out better than any antennae I've tried, and can be folded down when needed. It will bend if you whack it.
For trail use I have a Comet SBB-1NMO that I've grown to like. It doesn't care about trees, it gets out reasonably well for a stubby, and is dual band.
Where do you mount your Comet SBB-1NMO? I would imagine if placed on the yodateq mounts, it would not get above the roofline. Did you drill the roof for an NMO mount?
On the Diamond K400SNMO hatch mount.
