Save your box the transmission comes in - it's a real handy way to store the old one.
Here are some pics. I had to modify the shifter too. I just turned an end, then welded it on.
Those of you with a H55F do you start off in first gear, or second. Just curious if first is too low for road use
I sure wish I'd had all that info before starting mine.
If you're a DIY kinda guy, this should help:
ohhhhhhhhhhhhh man...add another thing to the to do list!!!Absolutely rebuild and inspect internal components of your tcase. In addition to the t-case rebuild kits. We stock all of the internal shafts, gears, collars and forks should you get in there and find something out of whack. Look for excessive internal spline wear on the input gear, seal surface damage on flanges, etc.
An alternative (albeit more $$) is just doing a complete new transfer case. If you but the trans/tcase/parts from us (very competitive price) we assemble the trans & tcase combo for free. So you get shipped a complete and ready to install setup.
Using these brand new Toyota cases
We ship you this
