4Cruisers
I'm looking into the multitude of options for installing an '84 H41 4-speed, from an HJ47 with ~47,000 miles, and a rebuilt '82 split transfer case into my '71 FJ40. The FJ40 has a '76 2F mated to a '78 FJ55 H42/transfer case combination (drum parking brake), with driveshafts from an early 4-speed FJ40.
1. I believe the easiest and least expensive option would be to swap out the rear axle with an axle from a late FJ40, using the 4.11 differential currently in the '71, driveshafts from a late FJ40, transmission crossmember from a late FJ40, and parking brake lever/cable from a late FJ40.
2. I've been researching the option of a split case with drum parking brake, which would still require the transmission crossmember, plus I'd have to have my driveshafts re-done. That option is pretty expensive, and I'd have to dis-assemble my transfer case to add the drum parking brake. The first option wouldn't require any work on the transmission/transfer case - it would bolt right in behind the 2F bellhousing.
3. I could try to source another early H41 like the one I have in my '76 FJ40, and use either a one-piece 3-speed transfer case or the '78 FJ55 case that's currently in the '71.
4. I could install a disc brake parking brake on the back of the split case.
5. I'll also look into using FJ60 rear drum brake hardware, with parking brake, on the '71 FJ40 axle. Starting my Internet search now. If the parts are compatible that might be even easier than option 1., considering I have all of the parts from my '86 FJ60 (it's getting axles and parking brake hardware from my '89 FJ62 donor vehicle.
Any input would be greatly appreciated.
