I've started down this rabbit-hole and was looking for some advice.
I have an 80-series fitted with a 1HDT/H151/HF2AV and stock US market diff gearing. Engine is running GTurbo/Intercooler/3" exhaust/etc and makes decent power. Currently on 33" tires. I live in my rig full time so it's quite heavy. I spend most of time running fire roads and average rough dirt, but I do wheel it harder on occasion to get where I need to be (I'm not out looking for difficult obstacles in any way) and only run highway when I have to, but then it's usually a full coast to coast run.
My two-fold (or multi-fold) problem is/are:
-5th gear in the H151 is not nearly high enough for modern highway speeds at reasonable RPMs. 35s would help ever so slightly with this, but likely not enough.
-1st gear also seems a bit low and I sometimes struggle not to lug it if the truck is pointed uphill at all. Obviously 35s will make this worse.
-In Low I could also use a lower 1st for crawling.
-It is a very early H151 (1990) and the parts are NLA to rebuild it so eventually it will have to be replaced (currently it's functioning fine however).
-I am considering jumping up to 35" tires which of course has me looking at re-gearing, currently looking at the transfer case as opposed to diffs if I swap to the H152.
Any input/thoughts/advice on what set-up might be the best for me moving forward? I've read that with decent power (like my set-up) 35s and an H152 are a pretty good pair with H152's lower first and higher overdrive. Can anyone confirm?
I'm also open to re-gearing the transfer case with 10% under Low and ... I'm not sure where I would need to be for High with 35s on my truck. Over and Under gearing is available. Kurt has a few nice charts on tire-size and gearing options but they're all for the US Market gas/auto set-ups.
