- Thread starter
- #61
Sorry, sold!
Confirmed that the non-US MT OBD2 ECU does get rid of the MIL, but you lose tach because the ECU came from an HZJ80 which never had a tach as they were bare bones models.
$2500 or so for the ECU.
The signal that drives the tach comes from the ECU. So with no tach signal the tach doesn't function.
Also, I know beno said "OBD2" in his post but I'm not sure that was ever confirmed. I don't dispute that the ECU supports OBD, but OBD comes in several flavors, especially for vehicles produced for non-USA markets. In particular, Toyota had a version called multiplex OBD, or M-OBD, that was prevalent in Japan and I always thought there was a good chance that the 89661-60340 was an M-OBD ECU. Lastly, even if the 89661-60340 has OBD-II it's not clear what standard it conforms to. The Mode 1 PID 1C parameter returns the particular standard the ECU adheres to and in the USA this must be "CARB" to pass emissions test in those states that require OBD-II. (No idea what Canada requires where you're located.)
You're mixing engine models and vehicle models. The 1FZ motor came in many variants and was used in several different vehicles that were sold in many different markets. In North America the 1FZ was only available in the FZJ80, but if you consider Toyota's world-wide market that was definitely not the case. The ECU being discussed here came from a HZJ80 vehicle that was not sold in NA but still used a 1FZ engine.
You need to take this up with @beno, but if he says the ECU came out of a HZJ80 vehicle then it did.
